Key Fob - Reprogram?
okloneranger
Earlier this year I replaced my cars battery. I actually had it out almost a month. My two key fobs now will not lock or unlock the car. Batteries in the fobs are good. Will I need a Viper tech. to make things right or can I do what is needed to make the Viper recognise the fobs it once recognised?:dunno:
might need one a tech with a DRB but try holding BOTH buttons down from inside the drivers side door. it should chirp and reprogram
if not, go to the dealer or call tator
okloneranger, as I am using a PDA, I can't see avitars or sigs...so, I don't know your year.
You do not need a Viper Tech or a DRB to reprogram your fobs...just follow Ron's instructions.
By the way...some confuse "resyncing" with reprogramming...different procedures.
O
okloneranger
Many thanks Plum and Steve. I don't know if that was called a reprogram or a resync, but what ever it was holding both buttons down did the trick. As usual, for me, I grasped only part of the instructions, and used only that part. This is the part I used. I sat in the drivers seat, fob and keys in hand, and held down both buttons of the one fob. In 5 seconds it chirped once. I then got out and tried the lock-unlock which worked fine. I had company so I came in. Here, an hour later I thought to thank you guys and reread the thread. I got to the part about doing all fobs in the prescribed time and figured I screwed the pooch. So, I took out the other fob and tried it. It works too. Thanks again.:2tu:
Dale04SS
