Kumho tire pressure
kARLUG
las vegas, nv
I just mounted a set of 18" Kumho v700's on the rear of my car. Does anyone know the recommended tire pressure for street driving?
GTSJERRY
powder springs, Ga
I think max pressure is 44psi, i always ran anywhere from 36 to 40 psi cold tire pressure in mine for regular street use and about 18 psi when drag racing.
PhoenixGTS
Phoenix Arizona
In run 30 psi and it seems to work fine. You will also be glad to know they are effectively run flats. I noticed one was down once (slight bulge in sidewall) and when I check the pressure it was UNDER 5 POUNDS! You could feel it driving but it would have gotten you back to home base if it was only a few miles.
