Leak detection pump connector?
ollikoi
Finland
I try to find leak detection pump connector.Pump is under left headlight but where is connector??? Wire colors should be WT/DG, DB/GY and OR . My car is -99 GTS
Garron
Remove the front bumper. Check all the hoses if you have codes they crack all the time.
dave6666
This pic is from my DIY triple fan at VA. I used the solenoid for a 12V+ ignition pickup. And yes, it's the solenoid in the front. The pump is in the right rear IIRC.
O
ollikoi
Finland
Yes, I have codes and front bumper is removed.
Wires is like in this picture but in -99 service manual I can see that there should be one connector more?!
Three wires. WT/DG, DB/GY and OR
Is it wrong information in service manual??
O
ollikoi
Finland
Operation and testing of the LDP video :)
[media]http://www.youtube.com/watch?v=95ZbPXQqoA8[/media]
Garron
The picture is a purge valve. The LDP pump should also be behind the front bumper for a 1999 and older viper. In 2000-2002 they moved the LDP pump to the right rear part of the bumper.
What is the build date on the door sticker?
dave6666
Thanks for the clarification on that. Yes, the car used for that pic is my '01 ;)
Brian R
