Eric
2001 with 2,000 miles. After returning from a cruise night and going through a little rain I parked the car in the garage and the next morning when I pulled the car out to clean I saw several drops of oil in the floor. After I got the car jacked up I could see several drops of oil on the fins of the oil pan. I put the car on the lift and could see that the oil pan appeared to be leaking around several bolts, even though they appeared to be tight. I had scheduled a trip to the dealer for another little problem and told the tech to look at the oil pan for leaks (remembering the past post about this problem). He raised the car and inspected the oil pan and determined it was a rear main seal, ordered one, pulled the trany, replaced the seal, installed the trany and tested. The leak reapeared within 1 hour. He called DC and they informed him that the problem was a hair line crack in the block above the seal, requiring the motor to be pulled and returned for inspection, repair or replacement (they had seen 3 others with the same problem in the past few months). Therefore, do not automaticaly assume the oil pan is the problem (if it is that is better than engine replacement).
