Lightest flywheel?
evomind
which flywheel is the lightest?
i thought it was fidanza, but im not sure.
(for a gen 3 viper)
thanks
KaiPL
Salt Lake City
Tilton flywheel is lightest you can get.
Not cheap, however, and you've got to replace the stock clutch with a carbon/carbon Tilton clutch.
Crazy free-revving.
E
evomind
hmmmm, not really looking to swap out the clutch, but good info nonetheless....
thanks
Nader
New York
Crazy free-revving.
Kai is it tough to get the car moving in 1st? Does it buck alot?
Greg-TT
Irvince, CA
I put the 19 lbs Fidanza aluminum flywheel in my SRT10 and I couldn't be happier. Many people warned me it would buck alot but I didn't really notice the difference. I drive the car a lot (12K yr) and it feels and drives just about right. Only noticeable change was free revving engine.:2tu:
With the help of light flywheel and 3.55 gears, I usually jump ahead of Z06
YouTube - Greg Viper SRT10 vs C6 Z06 40-145mph race
Cape Coral, FL
Tilton 12.5lb flywheel is much too light for street use, you will kill your clutch life. Tilton heavyweight [still lighter than OEM] is the way to go.
Remember, with a Tilton, not only are you losing the flywheel, but also the pressure plate altogether. The pressure plate accounts for 50% of the inertia for starters. The "lightweight" Tilton has only 15% of the mass moment of inertia of the stock assembly, while something like a Fidanza+OEM clutch will retain about 80%.
I hope that puts it into perspective on just HOW big of a change the Lightweight is.
No members online now.
JpKL
