Limp-in mode?
phiebert
Victoria, BC, Canada
When the PCM has entered a Limp-in mode (identified a failed emission component) what exactly does it do? Does it change the A/F ratio?
I have something wrong with my air temp sensor that I am trying to figure out. I get a code 23 and my check engine light comes on and stays on once in awhile (until I shut the engine off). I read that if the light is on the engine is in Limp-in mode. Just wondering what that means because it doesn't appear to run any differently.
Nadine UK GTS
Bath, Somerset, UK
For a '97:
Code 23 is "intake air temp sensor voltage low / high"
Basicly the voltage to that sensor is below or above the acceptable voltage. Yes, your check engine light will be illuminated during engine operation. But I don't think you will go into limp in mode (when MIL is on all the time).
Did you start the engine with the IAT sensor unplugged? This will trip a fault code and illuminate the MIL. Sometimes, the light will clear after several key-on, key-off cycles, but the code will still be in memory.
When one of your sensors dies, the computer begins to take readings from others and interpolate a surrogate value based on long-term adaptive fuel strategy block values stored in the PCM.
Motor City Mad Man
Las Vegas, NV
I hear a ground up ****** tablet in the gas tank works good to combat the limp-in mode. Should also add about 50 hp.
