I am replacing my oil pan gaskets because the bolts had minor oil leaks on them. Found the gaskets riddled with cracks around it. While waiting on new parts to arrive I found the at the rear of the motor the crank scrapper/ Windage tray has a crack in it. I cant find anyone that makes a replacement; I can get it MIG welded but my concern is why it cracked to begin with (only 20k Miles). When I looked up I found in 1993 the windage tray was one part number up to car #104, my car #105 was the first one to get a new part number that carried thru to the last gen1's. Looking for suggestions on a replacement or if anyone has seen this before. Also, anything else I should look for while the pan and windage tray are off?
