Looking for help with stripe size / placement
Joe Dozzo
Golden, CO
I found a 2002 post which mentioned the stripe width, but I've found nothing online or in my service manual about stripe placement. Anyone know where I might find info to properly locate the stripes I'm going to have painted on my 2001 GTS? Dimensions like so many mm from body line or off center?
Any help would be appreciated. Thanks!
ViperJoe
Virginia
The striper eyeballed mine on the 98 and it was like a 32nd of an inch off. NOT visible to the eye.
2001 - 8 inches wide, 4 1/2 inches between the stripes
2002 - Stripes are 8" wide, 4-7/16" between the stripes
1996 - GTS's, the stripe width is 8 1/4", 3-15/16" between the stripes
96 - 209mm-100mm-209mm
97 up (changed again in 2000 or 2001 I think): 203mm-112mm-203mm
starcity
San Francisco Bay Area, CA
Where can this information be found? I am curious to see what years, colors, etc. GTS Viper's came with stripes (factory installed). Thanks for any information you can provide.
Chris
ViperJoe
Virginia
Check the registry.....it's all there, and more!
Chris
