Lowering SRT front by 1/2"
Vipermann
Texas
Lowering SRT front by 1/2\"
Is there any way to lower the front by 1/2" or so? Parts rack make these 'cap things' ... do they work on SRTs? are they strong enough?
Snakester
Morgan Hill
Re: Lowering SRT front by 1/2
I'm not sure if this is what Parts Rack is selling, but Northwind Engineering makes low profile coil caps which replace the stock, taller coil spring caps, dropping the Viper's height by about 5/8". This reduces the noticable wheel well gap visibly, but without changing the stock springs or suspension geometry (even though it does require a realignment after installation).
It's a nice compromise that looks and feels better than stock, but doesn't beat you up with a harsh ride, or hang up badly on speed bumps and driveways the way that a full 2" drop does.
http://www.viperclub.org/Northwind/
I'm not positive if they are the same for Gen II and Gen III cars, but they might be. I'd say that they are probably as strong (or stronger) than the stock coil caps, with the Northwind units being made of billet aluminum. :laugh:
Vipermann
Vipermann
Texas
I would probably do that, but it doesn't show it being available for the SRT, only Gen 1 & 2
Herc
Parts Rack said they are not for the SRT 10.
Herc :usa:
edretti
Severn, MD
hmmmmmmmmmm, I need to fill the gap in the rear, front looks ok. Wonder if this would work as well.
Vipermann
Vipermann
Texas
Hate to pay that much ... only want to lower the front by a little
Vipermann
Vipermann
Texas
Anybody try INTRAX springs? (they're only $229 on ebay) or any other lowering springs?
Brian E
Granger, Indiana, USA
You dont want to install lowering springs on the SRT-10 OEM coilovers because there is not enough stroke. You will blow out your seals. Trust me, been there done that.
Skip, where are you? I was sure you would respond to this post long before me.
:2tu:
Riley Acr-x
