Max power of Stock Paxton Kit
V10TT
Miami Fl
Guys, on this kit as it comes from paxton (split second, fmu)
on a 97 GTS, what is the max hp that it is capable of?
What mods are needed to make 750 rwhp on 93 octane?
TIA.
Joseph Dell
Atlanta, GA 30338
When Boost Almighty had a stock paxton installed on his car, a conservative set-up was at about 700rwhp if I remember correctly. That was with a big pulley (read: less boost). put a smaller pulley on there (move from a 3.5" to a 3") and you should get 750.
JD
LS6 Molester
So Cal
i made 650rw amd 630tq with no problems on my car with the stock paxton kit. i had headers, no cats and borla pipes. no fuel system. 97gts
plumcrazy
ALL OVER
id prefer to keep it at 650rwhp. anything over that and i constantly hear that the OEM fuel system cant keep up.
V
V10TT
Miami Fl
thansk guys!
Boost almighty UGR car did make 750 rwhp, but it had AEm with fuel rails, 75 lbs. injectors, and in tank aftermarket fuel pump system.
1MEANSNAKE
Prince Frederick Maryland, On the Chesapeake Bay
Call Kevin at Underground Racing!!!!!! They have custom fuel systems, and can extract the absolute most out of these things! Paxton should be ashamed to call theirs a fuel system lol, it's junk. You can buy the kit as a tuner kit w/o the crap they give you for fuel management and add your own fuel system etc. Kevin has these kits and can get you everything you need!
countourcafe
