Mechanical Gauge vs. Electrical
SYNFULL
Bucks Co, Pa
I am installing a Innovative XD-16 air fuel gauge and want to install a boost gauge also. It's mostly for the bling effect in a pillar pod since I have 2 spots to fill. My question - is it worth like $100 more the get an electrical gauge over a mechanical gauge and running a vacuum line into the cockpit.
BOTTLEFED
Pocatello,ID
I've always used mech. boost gauges on my turbo cars. They work just fine and there is almost no benefit with the elec. ones.
More so, if you are just using it for cosmetic purposes, there is no need for the elec. type.
chimazo
Clarksburg, MD
The only reason I ever ran an electric boost gauge (as opposed to a mechanical) was that I wanted a recall/memory function. Other than that, I can't think of any compelling reason.:dunno:
dave6666
After 27 years in the chemical industry, my opinion of mechanical gauges is they all ****. And we have expensive ones costing hundreds each. Not that electrical gauges are God's gift to automobiles either, but I believe a quality sending unit and gauge can offer better accuracy and repeatability. Look for a gauge that can be calibrated range and span if they make such an animal for cars. Also, on a mechanical gauge if your line gets compromised, you have a leak.
But as you said, you're thinking poser mod. Yeah, right. You'll start using those figures for tuning. You know you will.
Might as well get a good one!
PM me if you decide to do it and want to see how accurate it is. We have our own NIST traceable calibration equipment here.
Tom F&L GoR
Wappingers Falls
Mechanical gauge response is almost always faster than electrical - as anyone with an oil pressure gauge knows. Also, if you train yourself not to become fixated on the number, but on the difference (is it now reading higher or lower by a bit) I would trust a mechanical gauge before electrical (auto grade) gauge. Dave's blood pressure is probably measured by a "mechanical" cuff, so they don't all ****.
SYNFULL
Bucks Co, Pa
Thanks guys- I ended up going with this one
Auto Meter C2 Analog Gauges
Gauge, C2, Boost/ Vacuum, 30 in. Hg/ 20 psi, 2 1/ 16 in., Analog, Mechanical,
and the XD-16 for the A/F
