TCKTPLZ
Well before any of you start to berate me on creating a topic as seemingly absurd as this, give me a chance to explain myself.
A while back I pretty much bought all of the MGW accessories for my snake. I installed them all and have been very happy with them. From what I can remember though I did run into somewhat of a problem with the dipstick handle.
As per MGW's instructions, you are suppose to tighten the setscrew on the flat side of the dipstick:
Problem is, when I do this and follow the instructions, the dipstick does not align correctly:
As shown above, the dipstick handle is in a vertical postion where as it supposed to be in a horizontal position as shown below (note: dipstick is not fully in and is just dangling to show what it is supposed to look like):
To get around this when I originally installed the dipstick, I just tightened the handle to the unflat or "side" of the dipstick. It seemed to be on pretty good so I never really thought of it again.
However, this is where the problem occurs. After cleaning out the engine bay I decided to check the oil. I pulled on the dipstick handle and sure enough it slid right off the dipstick. It seems that it was just dangling there. Good thing it didn't fall off.
I know this is from tightening the handle to the unflat part of the dipstick. The unflat part just does not provide enough surface area to adequately fasten the handle. However, if you follow MGW's instructions which state: "When you put your dipstick back in your car you will see that if you do not tighten the screw against the flat side of the dipstick it will not orient correctly," the dipstick will NOT orient correctly. It remains vertical as shown above and not horizontal.
This leaves me to believe that perhaps when making this particular dipstick handle the machinist drilled the hole for the setscrew on the wrong side of the handle. If you follow MGW's instructions it will not align and if you tighten it on the unflat side of the dipstick it will just come right off.
Has anyone else encountered this problem...or should I just take a long walk off a short pier?
Thanks for taking the time to read all of this. To those of you who could not find any value out of this useless drivel, here is a nice picture to look at :
