TowDawg
OK. A shifter install should be a piece of cake. I've done on plenty of other cars and never had an issue. Unbolt the old one, drop in the new one and you're done.
I just got my MGW shifter from Mark, so I figured I'd throw it in and see the difference. I decided to go in from the top side since I JUST took the car down off of the jack stands the other day. I pulled the center console out and got the old shifter out and the new one in. The shifter will move to the left and I can get what feels like gears 1-4, but it WILL NOT move to the right. I don't think I can get 5-6 and it definitely will got get reverse. I pulled it out and re-installed with the same results. Then I took it out and put the stock shifter back in. SAME THING! What the heck happened? I know there is a reverse lockout solenoid that you undo if you go in from underneath, but I didn't do it that way. The only things that I unplugged were the lighter and windows on the plastic console area and the passenger airbag on/off and power source inside the little glove box area on the center console. I can't see any of those causing the shifter to not move to the right at all.
I'll give Mark a call tomorrow for some advice, but I'm hoping someone has some kind of idea of what's going on here. I want to get this thing back together and go give it a run!
