MGW shifter with stock shaft and know
vpr hlr
Ottawa/ Naples
Changed out the shifter to the MGW. I still want to use the same KNOB from the factory. I just want a lower shaft. I took off the cap on top of the knob and there seems to be a "blob of plastic" leveled out. Any other suggestions?
CPPRHD265
Have you taken a look from the bottom of the shaft? Looking with a flashlight down the threaded hole, there looks like an allen bolt head down there... I'm not sure though, as it's really hard to tell. You'd need a long allen wrench to reach down there if it is.
Omaha NE.
Cut off from the bottom then and re mill the hole and thread. A lot of work though I would just get the MGW knob and save the work unless you have the equipment and like the challenge.
