Mopar roller rockers
ABADASP
Neckville Oklahoma
I am starting to install the mopar 1.7 roller rockers. The instructions call for the heads to be removed. While they are off I was going to have them ported & polished.What else should be done while they are off & where can I find the proper heavy duty springs, push rods & valve guides. I am also installing the cat back exhaust,70mm throttle bodies & computer upgrade. Thanks Mike
pauls
Akron, Oh USA
Be careful!! First you can install rockers with the heads on. Just cut the tab off the tool they send an use on valve springs to be sure of your installed hieght. Get the right length push rods from TNT. Collapse lifters completely before installing push rods and adjusting valve lash.
Porting??? without cam and intake mods, could hurt more than help. If your a drag racer the 70MM hurt as well. Only good on the big big end.
I suggest not touching the engine internals with your bolt ons. You'll go faster.
Good luck
naimsito
