MSD Booster help please
Q8
Los Angeles
Hi
im installing the msd boost a pump and i need to know which wires to hook it up to ? do i have to drop my fuel tank and find the right wires? thanks guys and merry christman everyone :laugh:
1TONY1
Dalton Ga. (Chatt. Tn.)
I mounted my Kenne-Bell BAP behind/above the amp in my GTS and tapped into the fuel pump wire that is in the harness/relay box beside the amp. I assume your relay box is in the same area. If you can't figure out which wire, I can look at mine.
XLR8
Mesa Arizona
I just put one on my car. I mounted it on the drivers side foot box and ran the wires through the transmission tunnel to inside the left rear tire. I removed the tire and found the wiring harness there and tapped in. It took a while because there was not a lot of room to work, but if you take your time it is not too bad.
Q
Q8
Los Angeles
Thanks guys :2tu: ill take a look near the amp and under the tire to see if i can find the wires :laugh:
HavikPerformance
