My A/C Not Blowing Cold Air.
Joseph Dell
Atlanta, GA 30338
This is quite typical in vipers from what i've both heard and experienced. probably a leak. question is where... and how bad. refilling is easy. but will it hold? that is the money question...
JD
LIVIPER
New York
Common problem. Your local dealer can refill the system and add a dye. The next time you have the car serviced they can use a black light to detect the location of the leak. That's what they did for me. Depending on where the leak is and how bad it is, it can take 4 weeks or four years to deplete.
Cal Viper
My 2001 leaked at the hose-to-compressor seals. New "O" rings solved the problem. Also replaced expansion valve and filter-dryer.
Silver Snake
San Diego, CA
My A/C quite working and it turned out to be the condenser and a couple lines need to be replaced. The dealer found this by using dye. The refill location is on the passenger side of the car. You will see a canister down by the side sill with two lines coming out of it. On those two lines you will see two ports, one is the high side marked "H" and the other is the low side marked "L". The low side is where you will attach the line to refill.
Mark
Jack B
NE Ohio
The Schrader valve on the low pressure (fill point) is a common point for a leak. Get a tool for tightening the schrader valve and loosen/tighten it a few times and spend $20 for a fill kit, you can fix it in 15 minutes. That is a Chuck Tatar tip.
AviP
New Canaan, CT
Mine was blowing hot and I refilled it. Damn AC has no cold temperature control and now I'm shivering.
V 10 MAFIA
Eat a Bomb Pop or hold a Snow Cone in front of the blower vent. Thats what I do.
Vreracing
Amarillo,Texas,USA
One of the mechanics I use charged my a/c and it took about 6 weeks to get low again. He mentioned that the repair work alone could cost 300 or 400 dollars. Since I only use the ac during the summer he suggested just charging it when it gets low.
At about $15 a recharge and about 5 minutes of work in about 6 and a half years I'll be at the break even point.
BarryLB
