Need Help ASAP. Engine Question about the years. Maybe questions for Jon B
Qualitywires.com
Louisville, KY
Are the 1998 engine specs different from the 2000-2002? Fuel, Compression, engine management (ECU)?
As far as I know there is no real difference between the engine specs besides the pistons being forged vs. cast and maybe a cam duration, but other than that fuel delivery, compression is the same right?
I need to get real advice on this please.
Thanks in advance.
C O D Y
Vancouver, WA
Re: Need Help ASAP. Engine Question about the years. Maybe questions for Jo
Different computer program becasue of the ABS and NGR, but I do not know about the engine.
ChoiceViper
Socal
Hmmm. Could this have anything to do with Paxton problems posted on the other threads?
KenH
Portland, OR, USA
Compression for all Gen 2's is 9.6:1 and Gen 1's were 9.1:1 per any documentation I have found. Only cam change was a decrease in overlap from 66 to 60 degrees for the creampuff years.
HSSSTOY
Ontario Canada
..Re-Engine specs. are the same with the exception of the Valve Overlap which is 66.0 degs. for 1998, and 60.0 degs.for 2000-2002. (International Viper Registry)
