Need Help: My Rear Hardtop Latches Broke
DodgeViper01
Central New Jersey
Well the problem is back once again but this time my warranty is up. Found out that the latches are not covered even by the extended warranty. Now my hardtop does not work and I have no idea what to do. Was on a run yesterday and had to use scotch tape to get home. What do I do now? Called Chuck and nearly passed out once I found out how much they were; ALMOST $500 EACH!!!! :eek: Anyone know where I can get latches or does anyone make any? I am in bad shape right now as I can not drive with the hardtop on.
99 R/T 10
Enterprise, AL USA
If the soft top latches are the same as the hard top latches, I might be able to help out. Hey Keith, ask Chuck if they are the same. :2tu:
D
DodgeViper01
Central New Jersey
99.9% sure that the latches on the rear are the same. Have an extra set? I will be able to double check with Chuck tomorrow also.
D
DodgeViper01
Central New Jersey
Trying now. Hopefully they will have some luck. So far I have spoken with about 4 different vendors and nothing. My last shots:
northwest engineering
262-377-6057
JonB @ PartsRack
V 10 MAFIA
Here you go my secret weapon:
These guys have everything:
Mike and Paul 270-726-9539
