need help with brakes 96 rt
adamlotus
los angeles
hi i was driving my rt 10 and all of the sudden my pedal became hard as a rock,found out the booster stud which attaches to the master was cracked.so i changed my power booster,pedal feels ok but t feels like it only my front brakes
are working just doesnt have that grab feel.do you think i have a bad porition valve?any ideas thanks.
adam
Tom F&L GoR
Wappingers Falls
Please clarify: the booster stud means one of the four studs attaching the master cylinder to the brake booster vacuum reservoir; the rod inside the master cylinder that the brake booster pushes on to activate the brakes; or something in the linkage between the pedal and the brake booster?
None should affect one end of the car vs. the other end. Was there something else that happened during the repair (disconnect any brake lines?)
PDCjonny
sounds like preportional vavle..CHUCK WHERE ARE YOU VIPERWIZARD!
Chuck is in jolly old England I believe for a week. He's an international superstar! :2tu:
countourcafe
