Looking for the location of the 5/6 point seat belt threaded hole postions that are under the carpet. Been trying to feel thru the carpet to no avail. Anybody have some measurements before cutting??
I would recommend that you remove the seat, 4 bolts, and lift up the plastic side sill. Then you can pull back the carper and insulation so you can see the holes.
Mine had a bolt in it so you could not find it with an Ice Pick. The only side that has the bolt is on the center transmisson tunnel. The outboard areas you use the existing seatbelt anchors.
