NewYear Promotions from DC Performance!
Dan Cragin
LA, CA
The New Year is here and we want to thank everyone for your continued support.
We have been here to serve your needs since 1992 and want to continue to serve the Viper community for many years. Please consider us for your parts and serve needs.
For the month of January, we have some great promotions:
Fluid Change - $699
You cannot beat this service special. First we will do a complete inspection of your car.
All fluids will be changed. Coolant, engine oil and filter. Brake fluid, clutch fluid, power steering fluid, transmission and differential lubricant.
Performance Evaluation and Safety Check- $75
We will perform a complete inspection and Dynamometer test. A complete report will be made with results and suggestions.
Air Conditioning Service- $55
We will evacuate and recharge your AC system with approved refrigerant. The system will be performance tested and leak checked.
Performance Alignment- $185
We will perform a complete suspension inspection. Ride height will be checked and adjusted as needed. Bushings will be torqued at ride height; camber, caster and toe will be adjusted on all four wheels.
Parts promotions for January:
Light Flywheel 1992-2002 Models $399
OE Replacement Clutch $299
Billet Transmission Crossmenbers $89
(Generation 2)
Performance Transmission mounts $69
(Generation 3)
Side sill Vents 1992-2002 $179
Smooth Tubes 1992-2002 $69
Computer Calibrations 1992-2006 $450
Paxton Superchargers ($1000 off retail)
RTTTTed
Thanks Dan,
Don't need anything but discounts are always appreciated.
Ted
eucharistos
Houston
And thank you Dan for your support of Vipers!
May God richly bless you in the new year and beyond.
Omaha NE.
These are GREAT offers from Dan and the crew at DC. Tony, Lyle, Chris and Dan are the best and we always support them as much as we can. Please take advantage of these great specials and support these awesome folks.
Thanks DAN!!!!
HAPPY NEW YEAR!!!
