No low beams
Bill W
Greenville, SC
I had an evap purge solenoid installed at the shop, and the next day I discovered I have no low beams. High beams and fog lights work. Is it possible that the mechanic might have dislodged a wire while he was working under the car installing the new part, or is that unlikely?
The solenoid is on a different circuit but same main connector to the PDC but different splice.
Check the old fuses with a meter and Magnifying glass.
Also use little pick or screwdriver and see if the filament asca break somewhere
JLNH
