NX NITROUS QUESTION....
RED 97 GTS
Noblesville, IN, US
I just bought a nx nitrous kit and it has jets from 100 to 300 shot. i have a 97 gts with headers,exh, no cats,3:55 gear,1.7 roller rockers,smooth tubes, k&n filters,vec 1, was wondering if this is an easy install and what size jet to use, i have stock half shafts will they hold up. Will this hurt my motor any. I am alittle scared to put it on my car. i would use it that much as i only race a couple times a year. thanks for any help.
MadMaxx
Simpsonville, SC
Don't make the mistake of "bigger is better"! Start small (75) and work your way up, monitoring for lean burn. If she goes lean, then cut the juice and start trying to find the problem. Lean = death to a motor.
These are wet kits right? Do they T off of an existing fuel tap or require a secondary source?
The trans should hold up fine, it's not a "hit" like most people think, rather gradual. The half shafts... I have no idea, the vipers are new to me.
That gear will incenerate the tires if you have your WOT switch in first
James
Mando9595
