Oil Leak Unusual
swexlin
West Chester, PA
I had my oil cooler lines replaced last year, because there were leaking, common problem. Well, back when I had the car on a lift a couple months back, I noticed seepage from a line the is in front of the pan underneath, it is a hose in the center, with two O-rings on it. Oil is seeping slightly out of there. Enough to make a very slight spot under the car, actually the spot is from the blow-back onto the belly. I thought the lines were leaking again, but this seems different.
What is that line? This on on an 03.
Thanks,
Dan Cragin
LA, CA
Could you be looking at the Air conditioning line just in front of the oil pan?
swexlin
West Chester, PA
Steve, we did look at it when we had it on the lift back in March. I'll see you in Carlisle in a few hours! Thanks!
AbsolutHank
Odenton, MD
No, I mean the source of the oil leak is probably at a point higher...you need to be following the oil trail, starting from the drips on the A/C hose upwards...it could certainly be those lines, although if they were recently replaced I'd doubt it.
swexlin
West Chester, PA
Thanks Hank. What is above there that could be leaking? Looking down topside from the engine with a flashlight, everything appears dry, including the oil filter and top around the oil filter.
Sonoman
Sonoma Cownty
It turns out that just about any leak on the front side of the motor ends up dripping off that A/C hose. Leaks other than valve covers or cooling lines can be more difficult and costly to fix. Could be front part of the oil pan or front main seal (crankshaft). Some of these leaks only occur when the oil is cold and pressure is highest (keep RPMs low until car has warmed up). Obviously we all want no leaks, but if it is just a couple drops and the price to repair is high, a judgement call may be to keep an eye on it (or on the garage floor!). Maddening though; I've fixed a couple hose leaks so far and holding my breath (somewhat skeptically) that everything will be good to go for a while.
swexlin
West Chester, PA
Sonoman, good advice that I already follow. In any car, I never get revs up or "get on it" until fully warmed up. As I said, it seems very minor, and rarely is enough to even drip on the floor, just a few drops. I did a 200 miles round trip to Carlisle and back yesterday, and when I got home, check underneath with a flashlight, and there was hardly anything there, and no drips. So I may just "live with it", and monitor it, as you say. Thanks for your reply.
What is maddening as you say is that when I inspect from topside with a flashlight, I see nothing, everything dry. Next time I have her in for service, I'll have the tech take a look.
Steve, I'll be in touch to get it on your lift this coming weekend or next, depending on your schedule.
wikkid
I would definately find the source. It would bother me that much. Let us know what you find.
swexlin
West Chester, PA
Update:
Had the car to the tech today, up on the lift. Oil cooler lines not leaking. Bottom line, they cleaned up everyting dry as a bone, put dye in the oil. They put 30 miles on her, she's dry as a bone (as was the garage floor after sitting for a week now). I have to go back in 200 miles (about 3-4 weeks for me) and they'll take another look.
swexlin
West Chester, PA
Update: looks like it's the pan gasket, very slight. So, I'm gonna live with it. There is some wetness at the seam near the bolts at the front of the oil pan, and I guess over time it just runs down. Never drips on the flat garage floor, only time it did was when I was parked on an incline, and the accumlated residue on the bottom of the pan ran due to gravity.
swexlin
West Chester, PA
Over a year later, and still have this annoyance. I know everyone says just live with it, but I'm anal. I guess the only advice is to change out the pan gasket? Or maybe I'll still just live with it anally, LOL!
TRACKDAY
Woodbridge, VA
If the price to replace the pan gasket is reasonalbe, then go for it.
I'm just like you and very anal (or OCD :mad: ) about my cars. I would lose sleep over this LOL.
If you have it repaired, then you will have piece of mind knowing the problem is solved and you won't have to deal with it again (hopefully)
.....good luck :2tu:
Cape Coral, FL
Replace the gasket. Its not big bucks, nor a big deal... and its worth it for cleaning and double checking the pan slosh plate bolts while you are in there.
swexlin
West Chester, PA
Yeah, you're right. I'll probably wait until spring when the car goes in for PA inspection and service. I'll do it during my standard oil change. By the way, what are the slosh plate bolts?
swexlin
West Chester, PA
I appreciate the advice gents, thanks. I did some thread searching yesterday, and I found others with the issue. Minor, to be sure, but still annoying.
victoryman100
Trafalgar IN.
I had the same problem, Up on jack stands, drained oil , removed filter, removed bell housing access cover, took ac line clamp bolt off, pulled dipstick tube out of pan, removed pan, cleaned , installed new gasket with sealant in corner seams, reinstalled all, new filter and oil. all done in about an hour taking my time. VERY simple job.:drive:
VIPER R
Why not think about the updated pan and pick-up while you're at it
naimsito
