Oil change time, normally do as much of an inspection around the engine/undercarriage as possible. I found two things, oil leak and the source of my irritating exhaust leak. From the looks of the oil in the following pictures should I be concerned. This is the rear of the head on the passenger side bottom bolt, 96 GTS 37k miles.
And the source of the exhaust leak, directly above the starter.
Thanks,
Chris
Thanks,
Chris
