passenger side rear view mirror
happy56
Mooresville In
My passenger side rear view wiggles and is loose in between the mirror and base the base is supper tight to the door(i have the panel off) and it looks like there might be a bolt behind the mirror itself. How do I get the mirror itself out so I can get to the bolt ?1994 model
Rotate mirror toward rear of vehicle to expose the bolts...remove them, then mirror and gasket. Reverse to install. Turn on your fax machine, then call me with number to get 1994 Service Manual instructions and diagram if needed (which I doubt you will need !!).
H
happy56
Mooresville In
317 887 6317 fax cell 317 644 9578
