Performance rear end
V
vegasviper
Guest
Who builds high performance rear ends that can handle our SC cars?
PhoenixGTS
Phoenix Arizona
Unitrax is the preferred source for both the internals and two power levels of upgraded half-shafts. Most of the vendors popular on this site resell Unitrax's services or you can go to Unitrax directly.
V
vegasviper
Guest
How does the Unitrax rear end compare to the Quaife?
PhoenixGTS
Phoenix Arizona
They just rebuild the stockers so it is a locker - not a Torsen like the Quaife. Not as sophisticated, but probably stronger, effective, and a third of the price or less. Quaife might be worth if if you tracked all the time, but for drag racing no way.
Camfab
SoCal
Actually the stock rear end is a limited slip design and not a locker, you probably already knew that though.
MAVERICK
South Florida
Tommy Archer did mine, took them about 2 hours to install the Quaife.... you should also consider the heavy duty half shafts.
