Performance Viper Cam Shaft Hydrolic Lifters HELP !
2002_Viper_GTS_ACR
Charlotte, North Carolina
Hey Folks,
Anyone know of any decent hydrolic roller lifters that are used in the viper, so we can run higher spring pressure then stock and not have the lifters collaps? I am talking about enough to get a decent increase over stock, lets say anything from the 130-140 LBS seat pressure range ? The stock ones are probably good for up to 120 or so. Not an expert, just what I hear.
So I really want to be able to take my port and polished heads up to 140 lbs seat pressure for "boosted" use, but stock lifters will bleed down/collapse on me at higher RPM use with that high of a seat pressure.
I found crower cams makes a 66326 one just for the viper, but dont know if its anything better then stock. Any ideas ?? Any other options ?? That dont cost an arm and a leg ??
Jon
Bugeater
Virginia Beach
I see you are about to connect the large cables to Frankenstein's neck again....*** car is coming out of your garage this time??? Will it have 1,000 hp when all is said and done? lol.
Cant wait to see (or should I say gaze) your beast when all is said and done Johnnyboy!!!
2002_Viper_GTS_ACR
2002_Viper_GTS_ACR
Oh dont worry JohnnyBoy, Daddy (me 2 U) had you beat already at VIR with my previous mods alone, this is gonna make it so your own wife crys. hahahahah...
j/k I'll keep you posted on the beast as she progresses !!
Jon
Martin D
Dunwoody, GA USA
Try giving David McIntosh a call over at McIntosh performance. He did my headwork...and My springs have 195 on the seat and 520 open.
He should be able to tell you what to get. 678-513-4500.
Regards,
2002_Viper_GTS_ACR
2002_Viper_GTS_ACR
Wow, thats a lotta seat pressure. BUT you are running SOLID cam, so your lifter isnt gonna do me a damn bit of good. I will call David, but unless he does hydrolic roller upgrades, he might not be able to say.
since HEFFNER PERFORMANCE SPONSORS THIS SECTION, COULDNT OLD JASON KICK DOWN SOME LIFTER INFORMATION ?? :-D
JON
Martin D
Dunwoody, GA USA
True. I do have a solid. But David also did my 650R heads back when I was still running a hyd.... He is a pretty smart guy!
99 R/T 10
Enterprise, AL USA
Hey you skirt, if you were at BG you could have talked to him yourself while drinking a cold one........... just after getting your asss spanked by me! :D He may still be on the drive back from BG until late tonight.
Torquemonster
Auckland, New Zealand
Heffner has found a hyd. lifter that suppresses pump up much better than the stock ones - ph 410 766 2800.
The stock lifters **** once you go to a bigger cam or add boost and rpm past 5500rpm.
2002_Viper_GTS_ACR
2002_Viper_GTS_ACR
Thanks a bunch on the Heffner hint !!
I just called him, he was out of stock but expects to have more on the shelf in a day or two !!
So I'll be buying some as soon as he gets them in !!
Thanks again Toquemonster, AND Jason Heffner !!
Jon
Retart13
