Pic of stock alpine stereo rear gen 2
steel snake
Nevada, Washoe county
Thot I might add: if you decide to remove bezel assy it pops off pretty easily. I think the pix show you the clip points....2 on top, 2on the bottom sides in the window switch area and 2 in the center of the ash tray- shifter plate. The corners nearest the driver and passenger are held down with the rigid equivalent of velcro. A flat piece of wood or plastic will be your removal tool. I made one out of one of my wife's old cooking spoons. The spoon part make a good handle. Putting it back together I used a very thin coat of light grease on the spring clips. The spring clips still work and next time will be easier. Just be careful and nothing will break. Have fun.
Mando9595
