sbkim
About a month ago, I finally had chance to install Eibach lowering springs on my 2002 GTS with the help from many of our forum members but especially from Lethal GTS. I must have called him gazillion times to figure out the installation - Thanks!! First, I did the install at home and it was NOT a pleasant experience. I won't bore you with all the details but here are my takeaways:
1. Getting the old shock assembly out isn't difficult - 2 bolts at the top and bottom. The front bottom may appear to be impossible to remove but if you hit it just right with a hammer (hehe), it will clear the tie-rods.
2. Definitely seek out a local shop to compress the springs for you. Not too many shops would offer this help but one did at a very reasonable price of $20 for all four.
3. I rented a Macpherson shock compressor from Autozone. It works but you will end up having a popeye size forearms and burning at least 30min each.
4. I also adjusted the shocks as per many instructions posted on the forum. I set the fronts at almost full (stiff) and back in the middle.
5. Putting the shocks back in was also a major PIA. Just make sure you have a good pry bar ready!
6. After about 100 miles of driving, I also ended up getting a four wheel alignment using factory specs since I do not track the car. If you are in the chicago area, I highly recommend Addison Alignment shop located on Lake St in Addison IL. They have a drive up bay so they can accomodate even the lowest cars. It took about 2 hrs and costed me $140. Before the alignment, the car felt extremely twitchy and was significantly off from factory specs - esp the toes.
Overall, I am very pleased with the looks of the car after the Eibachs. Ride quality really hasn't suffered much. It is slightly harsher but there is no bounce (prob b/c I adjusted the dampning on the shocks). I drove about 100 miles after installing the springs and the car dropped slightly over an inch on all fours. Believe it or not, I did not experience bad scrapes either.
Now, here is the kicker I was not expecting. After the alignment - supposedly the toes were WAYYYY off - the car height increased. So, now it's about 1" lower than stock. If you want to drop more than 1", either don't get an alignment, get those modified spring caps, or spend thousands and get adjustable coilovers.
These are terrible pictures but you get the idea. Overall, a great mod for $250 springs (ebay) + $20 (spring compressing) + $140 alignment.
Before:
http://home.comcast.net/~sbkim/wsb/html/view.cgi-photo.html--SiteID-1595086.html
http://home.comcast.net/~sbkim/wsb/html/view.cgi-photo.html--SiteID-2663011.html
After (Eibach but before alignment)
http://home.comcast.net/~sbkim/wsb/html/view.cgi-photo.html--SiteID-2663014.html
http://home.comcast.net/~sbkim/wsb/html/view.cgi-photo.html--SiteID-2663017.html
http://home.comcast.net/~sbkim/wsb/html/view.cgi-photo.html--SiteID-2663019.html
Before:
Reinstalling was difficult mainly because you need patience to be able to squeeze the shocks into the mount and be able line up the bolts.
