Power steering vent tube (where to get one)
FLX109
Massachusetts
I been hearing alot about loose Power steering fluid caps and this solves the problem, where can I get one?
FLX
95Viper
Phoenix
As of today, in an interest to get this product advertised to as many owners as possible, HiPo Engineering has stopped selling directly to consumers. We have teamed up with premier Viper motorsports vendor Archer Racing www.archerracing.com 218-727-4806.
John Archer will be selling these at all Viper Days events, VOI in Texas and will advertise in the VCA magazine. Thanks everyone, Craig
Tom F&L GoR
Wappingers Falls
Being cheap isn't for everyone, but it you are, here's a method that works fine. Bring your PS cap into the auto parts store and get a rubber hose that fits over the ******. Buy about a foot's worth. Stick the end in the hole in the plastic inner fender well. The cap won't get lost because it can't untwist against the rubber hose, which is wedged in the fender well hole. Not car show material, but effective.
OK, should be a hose clamp. But when I did it, that's what I had and haven't changed it since.
End of tube inside wheel well.
Yes, XGTZs.
Hisserman
Waterford, MI
Tom --
Power steering fluid can be nasty stuff. Have you seen any evidence of deterioration of your rubber hose?
Tom F&L GoR
Wappingers Falls
Yup. Some elastomers get very soft. Don't use coolant overflow rubber hose (very thin walled stuff.) Rubber hose with braided nylon (fuel line) should be fine.
95Viper
Phoenix
Tom, I'd be worried about 2 things
1. The HiPo Engineering hose is made from Viton rubber at something like $12 per foot. Compatible with power steering fluid which will deteriorate over the counter rubber hoses.
2. Stuffing the hose into a hole tight enough to stop the hose (and cap) from turning would mean that it would pinch the hose. Venting of the reservoir is extremely important.
