Cat Back options - where to buy?
cnpnh11
New Hampshire
Hey all - I have a muffler that's rusted out and I'm looking to ditch the muffler and go with an x-pipe setup instead. Does anyone have a good link or online store where I can source a quality setup for this situation? Thanks!
white out
The Mitten
Message sent.
Borla and Corsa are hands down the two most popular options and people will die on a hill fighting for which one sounds better. Borla is the original Mopar 2 muffler system, Corsa is a 4 muffler system. Both are 3" diameter.
Note* Borla has 2.5" inlet for stock cats, but can be modified to accept 3" (headers) where the standard Corsa is 3" inlet (requires reducer to fit stock cats) and the 2.5" Corsa inlet is special order.
When replacing the exhaust, it is a great time to vent the rocker panels to keep cabin temps down.
So I wont fight on the hill between the 2 but I have the Borla 3" Cat back. I personally like the sound of it.
Monopoly
Toronto
My car came with the rear muffler delete. Just straight pipes from the stock resonators. I got a shop to install magnaflow high flow cats which is the best gen 2 mod for the money. I can’t justify spending that kinda money on a corsa unless you’re replacing headers to go full 3”.
asuj158
Indianapolis
Message sent.
What do you mean by “vent the rocker panels”
So cutting slits in it for heat dissipation? I’m guessing on the bottom?
Yes. Check Dave6666's posts, but what White Out was referring to was cutting the liner and leaving it open like he has then someone decided to make side sill vents to sale.
