adamlotus
i have been tryin to sell my 06 vert for months not a single call and i just checked ebay theres alot at buy it now in the high 50s wow the prices have dropped big.
I know this is a little exceptional but I paid,... $50 K.
here we go again.. to me an 08 is NOT an identical car to the 06
'the 08 Viper. So it's got the brand new, variable valve timing, all-aluminum V10; 600 horsepower, 560 lb-ft of torque.
Because of the engine's brute force, we had to beef up the rest of the drivetrain (on all 2008 Vipers), so it goes like this: Stuck on the back of the motor, instead of the big, single-plate clutch, is now a smaller-diameter, dual-plate, dual-disc clutch that reduces our rotating inertia by about 18 percent. So throttle response is pretty damn good.
We backed that up with a modified and improved T6060 Tremec 6-speed manual transmission. It's a double-overdrive manual gearbox. What's unique about it is that we changed the synchronizers in first and second from a double cone to a triple cone synchronizer; it gives really nice first-second shift feel to the car.
The gears are cut wider to take the torque. They actually have a 10-percent wider gear face on 'em to manage the additional torque.
And then the axle is basically the same architecture, but it's got a brand new differential in it. We had what was called a Hydro-Lok in the previous generation car--which was the '06. We didn't have an '07 model year, we went from '06, ran that long and then we went to '08.
This car has what's called a Visco-Lok. What makes this really unique is that it has its own sump that it uses to generate the hydraulic pressure that brings the clutches to bear when the axle goes into differential activity. This is much more precise, it's much more progressive, and it allows you to put the power down much more easily coming out of the turns.
The older differential used the actual sump that was in the axle, and sometimes it would take a few milliseconds to prime--very short, but it was enough that you'd spin up the inside wheel and then when the clutch would come on it would upset the car, because it was a really abrupt engagement. The Visco-Lock is not like that, it's a real improvement.
$50K for an '06 coupe w/ 3,300 miles. I can't get over that - $40k off sticker for a 1 yr old car w/ full warranty...
i am enjoyin the car,i was wanting to sell my vert and possibly get into a 08 or getting into another car.if i end up keeping it i will most likely have it supercharged .i cant see my self selling the car for 50k.
FYI... I just bought a red/silver stripes '06 cpe. The car has 3300 miles, ripper shifter, Corsa track exh. and best of all, a Quaiffe diff. I ran the car on "car fax", "autocheck" etc. All good.
At that price I am currently in negotiations with Jeff to build a "Street Serpent Coupe"! Yeehaaaa...
This is the car;![]()
i bought my vert from performance dodge in az feb of last year.Good , hold onto it $50K is crazy, Who did he buy it from? His brother.
Did you check to make sure that is not a SRT Driving experience car?? I could have sworn they used one with that color combo.
There were 206 units built in Red for 2006 Coupes. There were a handful of the Red/Silver Striped cars if not purchased new that were put into the Skip Barber Racing School . 91 Car were produced with Silver Factory Stripes and the build numbers are also based on the wheels option, 10 spoke, 5 spoke. .
Great. That makes my red '98 GTS worth about $29.95.![]()
Who cares if it was? It doesn't have enough mileage on it to be beaten up that bad. That's a steal no matter how the car was driven!!!
Congrats on the great find!!!![]()
I am sending Jeff the deposit today to become "SS coupe #1" (car #7) I will paint the car Sapphire to match my 01 GTS... Can't wait. All because I "got a good deal".
