question for someone with 99-02 factory service/repair manual
hemibeep
Tampa FL
I am despirately seeking the wiring diagram for the power mirror switch. It would be great if someone could help rather than buying a 99-02 service manual.
8 wires:
1. yellow
2. yellow/ black tracer
3. dark blue
4. lt blue w/white tracer
5. white
6. pink
7. yellow w/pink tracer
8. black
when this is done I will share how to retrofit power mirrors to 96-98 gts. thanks
Joseph Dell
Atlanta, GA 30338
I've got the manual open to page 8w-62-2 and I don't know what you want to know. if you have a fax #, I can fax you the page...
JD
H
hemibeep
Tampa FL
I only have the 97 manual and am looking for the layout of the switch so that I can add power mirrors to the 97. I have the switch and the mirrors just looking to decode the wiring on the switch as I am making my own harness.
Joseph Dell
Atlanta, GA 30338
There is a slightly larger version in my image gallery.
If you need the 2.5 meg version (8 megapixel) send me your e-mail address.
Good luck!
JD
H
hemibeep
Tampa FL
The Email PIC was perfect.
I think the power mirrors should be worth at least 2RWHP.
Dave
H
hemibeep
Tampa FL
mirrors work like a charm. took some trial and error to get the wiring correct, but worked great.
Just used simple speaker wires. Ran a power supply with fuse from under dash.
Really, the reason I did this mod is because I needed new mirrors and the power mirrors cost less than the manual mirrors.
