Question for those with Hurst "Roll Control"
SRTim
Pittsburgh, PA, USA
Question for those with Hurst \"Roll Control\"
I had my roll control installed today. The button to activate it is located on my shifter. When I'm driving down the road, it vibrates and drives me crazy...it is made of plastic- it doesn't seem very high quality. I have to hold my finger on it when driving to stop the vibration. Does anyone else have this problem? If so, how do you stop the vibration??
Thanks,
Tim
Tom Welch
Blairsville, Georgia
Re: Question for those with Hurst \"Roll Control\"
Tim,
Mount the engage button on the turn signal or wheel tilt finger. I have seen it installed there and it works much, much better. Is it a little black plastic part with a red push button? The bottom of its assembly should be concave as to fit snuggly to a round post ie; shifter/turn signal arm.
Call if you have questions. Send me a digital pic of yours, if it is the wrong one I may be able to find you the proper piece. It uses two small black electrical ties that run through its mount to hold it in place. Mounted correctly it is virtually invisible and is easy to access with your left hand(while you hold the steering wheel if needed)
tom
Http://btrviper.com
Tom
SRTim
Pittsburgh, PA, USA
Tom,
It is the black plastic part w/ the red push button.
I will remount it at the steering column.
Thanks for your help,
Tim
JKGiant
