Question - Where is the physical location of the stock cross connects
Kevin Stitely
Huntingtown, MD USA
I just finished installing a new sound system complete with JL Audio speaker components, sub woofer, amp, and an Eclipse head unit. WOW WHAT A DIFFERENCE! Everything went well except for the cross connects. I could not find the original Alpine cross connects. Do they exist? Has anyone had this problem? Any and all advise would be appreciated.
K
Kevin Stitely
Huntingtown, MD USA
There's been 51 reviews of this question and no response. That tells me the question is not clear enough. Before giving up I'm going to restate my question again. Does anyone know where the cross connects for the stock stereo are located. I've looked everywhere, the doors and under the dash to no avail. Pls send me a reply if you anything to add.
Ulysses
San Diego, CA. USA
I reviewed this thread earlier and had the same response as Ron.
I assume you mean the crossovers? If you are then the crossovers for the rear are contained in the stock amp. The fronts use a high pass filter (read capacitor) which are tucked away in the door.
