questions for those with Autoform side sills
JST2CRZY
Deland, FL
On my 96 GTS, the passenger sill has some corrosion and paint bubbling. I am thinking about replacing both with the Autoform units and I have a few questions:
- How is the quality?
- How is the company for customer service?
- Did you use the factory insulation or a different method?
- Any damage to the fiberglass due to heat issues?
viper k
i have my 1996 gts side sills at body shop as we speak if they strip them weld corrosion area and use the right primer they will fine
Tom F&L GoR
Wappingers Falls
I will be installing some end of this month.
Customer service is good; I had a question and they actually called vs. email.
I will use the factory insulation .
They designed these for race cars, so there is a built in heat shield in the upper section.
I got a better than advertised price by going through JonB.
dave6666
I have them on my car. +1 on get them from Jon B at Parts Rack.
As far as quality goes, I give them an 8 out of 10. From a picky person, that's actually a compliment.
Complaints...
Pre-drilled holes did not line up on the bottom. Why drill them if I just have to fill them?
Edges wavy.
Crappy packing; shipping damage. ***?
Lots of time involved in what now is a perfectly fitting well refined part.
