MattInNC
While removing my fuel pump assembly from my 99 GTS, the quick disconnect fitting came apart on me. (the one that goes to the fuel pressure regulator)
Does anyone know the correct re-assembly order?
The green o-ring is still inside the female connector on the fuel line. So I am left with a yellow o-ring, a white spacer, a black spacer with a beveled edge and the blue two finger connector which goes on last.
Anyone? I attached a couple of pics as well...
