Rad fan issue
TexasTonka
San Antonio, TX
Went for a few hundred mile cruise today in my 96 Twin Turbo GTS today and all was great until I got off the highway and stuck in traffic, temp shot up to the red mark in about 3 minutes. I pulled over immediatly and shut it down. Popped the hood and after the rad stopped its small hissing sound I turned the key to the on position and temp gauge in the 215 range I cranked it on with heater blowing. Sure enough the electric fan was not turning. Fuses are all okay. Plugs seem to be connected 100%. Has anyone had one of these go out on them? Can I replace just the motor or do I need a entire new unit? Any idea of a good place to get one of these? It was upgraded to the 99-02 style when the bigger rad was installed at Heffner with the twins.
dave6666
See pic; right by the brake booster, above the DS footwell. Where the Ford relay is on my car - part of my custom fan wiring - that is the on-off relay. There is also a hi-lo relay. Either could be bad, look at the legend under the sanp-on cover for which is which. Also look carfelly at the pins and down in the socket for evidence of burning.
T
TexasTonka
San Antonio, TX
Relay looks brand new, no signs of burns or anything. Will replace just in case. Fuse was A okay as well.
T
TexasTonka
San Antonio, TX
UPDATE:
Swapped known good relays from my RT with the GTS. Still no movement from the Rad Fan. Any other ideas before I pull the entire assembly?
dave6666
It could certainly be the sensor bad on the head. It is $50 and easy to change. Would not be the first one to go bad. Doing it cold, you'll lose minimal coolant.
See if you can jumper the fan with a battery charger to make sure it works. Also if you have the wiring diagrams on your car check the power to the factory fan on-off relay. It should have power to the relay main side regardless of the coolant temp.
This is of course best done with the help of a good set of wiring diagrams. I have them on my '01 they may be the same for the cooling system for '96 if you need them.
T
TexasTonka
San Antonio, TX
Tell you the truth electrical diagnostics is new to me but if you have diagrams and can send out a brief description on how to proceed I can do it. Would appreciate the help!
BarryLB
