Radio experts....question on stock radio in another vehicle....
1TONY1
Dalton Ga. (Chatt. Tn.)
Radio out of a Gen2....Will it work without the amp ? I have another vehicle I want to put a stock radio in, it does not have to be jammin/loud etc......just needs to work. tnx
shifter
Novi, Michigan
Not likely, unless the other car had an external amp, and wiring would have to be run seperate or you'll need a custom harness. Your best bet would be to get a cheap head unit for the other car with a built in amp. Can be had for under $100.
Matt M PA
Langhorne, PA USA
According to the service manual..the amplification comes from the amp...so without an amp along with the unit..it shouldn't work. Plus, the radio is connected to the amp with a multi-pin connector. A good CD/Radio can be had in the aftermarket very cheaply, with an easier install.
jpolen21
