I bought mine a few months ago for $50, it looks and runs great!
But it's nothing compared to this bad boy :
- Scale => 1/10
- Chassis => 0.098" (2.5mm) thick 6065 aluminum, purple anodized,
countersunk.
- Drive => Four wheel.
- Drive Type => Shaft.
- Engine => 0.15 cu in (2.4cc) HPI T-15 with ABC construction, dual needle
5.5mm rotary carburetor, glow plug and large heatsink head, engine
starts by included electric Roto Start system.
- Power => 1.2 hp @ 29,000 RPM
- Exhaust => Dual chamber tuned pipe with header.
- Radio => AM 2-channel pistol grip with steering and throttle trims,
servo reverse, and steering dual rate.
- Fuel Tank => 2.5oz (75cc) flip top cap.
- Fuel => 2-cycle glow fuel with 10%-15% nitromethane, 16% lubricant.
- Clutch => 2-shoe.
- Transmission => Two-speed with adjustable shift point and changeable
gear ratios.
- Ball Bearings => Rubber sealed type included (18 total).
- Shocks => Four oil-filled with coil-over spring, composite bodied.
- Main Gears => 47 and 43 tooth, nylon construction.
- Gearbox => Sealed front and rear.
- Differentials=> Planetary geared, limited slip front diff.
- Brakes => Single disk.
- Tires => Treaded D compound high grip, premounted, 2.5" (65mm) outer
diameter, 1.9" (49mm) inner diameter, 1" (25.5mm) wide.
- Wheels => Chrome finish 1-piece split 6 spoke, 1" (25.5mm) wide
2.2" (52mm) diameter with hex drive.
- Suspension => Double wishbone.
