Boxer12
After installing Belanger headers and exhaust (battery disconnect) in 09, I am getting random multicylinder misfire. You can hear the valve clatter which is very audible on idle. Car has Mopar PCM, so it should adjust to the bolt ons, right? I have double checked all connectors, plug wires, etc. Nothing seems askew. Does the PCM need to be reprogrammed? That's all I can think of. I hope not. I have the OEM PCM, should I try swapping?
