Remote disarm not always working
cagleman
Just wanting to see if mine is an isolated case or what:
I get out and lock the viper using the remote...Come back and press the remote button to disarm/unlock and it does not work. Each time I have had to unlock the back window, reach in and open using the emergency release (at which time the alarm goes off), get in and use the key reset in the glovebox. I replaced the battery in the remote after the first time, but it did not apparently help.
I am sure the neighbors didn't like the alarm going off at 1:30am Sunday morning :(
Any of you have the same issue and how did you correct? Think it is as simple as a loose wire somewhere?
ByteMe
Kirkland, Washington
I had this happen to me once and I'm sure it was due to having the remote get "pressed" while it was in my pocket. If this happens a certain number of times, the remote won't work. To fix it you have to hold down both the unlock and lock buttons simultaneously, I think for 15 seconds. It could be something else in the alarm system.
jpolen21
