Removing hoops?
DMan
Maryland
Popped the viper logo plates and I see a couple choices on bolts, what's the exact way to pull them to gain access behind the rear bullhead. Vert of course. Thnx.
DholiRaja209
Turlock, Ca
There are 2 bolts per roll hoop, and they are long bolts. You can feel for them by putting your hand in the little opening
beerly
the bolts that secure the hoops are located on the inside side of the hoops and are about 2.5 inches long. use a 1/2" socket to get them out. basically, the bolts go horizontally through the hoop tubing. I have mine out now. Let me know if you need a better explanation. The hoops may take a little working to get them out once you have the bolts out, but each one only has two bolts holding them in. After that, six screws hold the bulkhead in.
Callaghen
