Replacement interior trim parts
sspeed
Charlotte NC
Hello,
I am having trouble searching the correct names for these parts to see if there are replacements available either aftermarket or NOS or even used. My car is a 93 RT/10. I have attached images of both parts.
One is the plastic trim part around the striker on the door. It appears someone has over tightened the screws and cracked it.
The other is the 3 foot long trim part that goes on the underside of the rear halo. Picture shows it removed. Mine is severely warped
Any direction is appreciated.
Thanks.
kssssnake
I believe that's the sport cap pad. I fixed my door trim with plastic epoxy from the back side. Splint it with metal. You can fill missing pieces with body putty and paint it. I've had no luck finding trim parts.
DJ'sviper
I bought a retro of the door bezel and it was to large for my 93. Maybe you would want to get in touch with autoform. They can make pieces and are very good. They are in Michigan.
