Talked to the service guy yesterday afternoon. He said that after they installed the RPS clutch/flywheel, they did the test drive and thought that the diff was bad due to noise and poor power.
After they replaced the diff, that test drive still showed poor power. So they pulled the clutch and looked at the components and everything looked good. They then started looking at the engine and noticed the blackened plugs on one side and white plugs on the other. They changed the oxegen sensors and took another test ride. The Engine Check light came on and the scan showed too lean a fuel mixture. They also looked into the valve issue (not sure if they actually pulled them and or what) and they don't think that is the problem. They have been in constant communications with the STAR (I believe that's what he called them) factory technicians for dodge. I get the feeling they (dodge) are really getting concerned about the lemon law thing.
BTW, I'm beginning to think the original diagnosis of bad clutch may have more to do with the power problem, than with a worn clutch disk. Although, there was some clutch disk wear and hot spots on the flywheel, I bet you could put the original parts back in and it would run just as badly as it is doing now.
Bill,
Thanks for the offer of setting up a talk with RPS. I sent the e-mail to
rpstc@sprynet.com on 11/19/04 and things have progressed enough now, that I don't think the RPS install problem was that real, so I will decline on your offer. But if any of their distributors want to mention this to them, I certainly don't mind, as I feel customer relations and feedback are very important if someone wants to keep their customer base. Again thanks.
I'll continue to update everyone on this issue.
A guy at work asked me if dodge was forced to refund my purchase price under the lemon law, if I would buy another Viper or new Vette/Porche etc. I told him I would still like another Viper, but based on how dodge has treated me so far, if Toyota really does come out with a 500hp sports car, I would probably go with that.
