Selling my ROE S/C
HOWFAST
Hawaii
Here is what you get.
GEN II Polished ROE S/C, polished tubes
5, 8, and 10psi pulleys
42# or 441cc injectors part no. 280 150 558
3 belts
fuel rails
Everything in the picture......
Same one listed over in the alley.
Here's a link to my ad in the classifieds:
ViperClub Classifieds - GEN II Polished ROE S/C - Powered by PhotoPost Classifieds
Gus//
D
DAMN YANKEE
Guest
Note: This is the earlier design air intake rear housing.
RobZilla
Jacksonville, FL USA
I assume these are all the necessary parts for a complete installation. Looks great in the pics:2tu: I have a '00 RT/10 that I would like to supercharge in the future. What are you asking for the complete package?
:usa:
H
HOWFAST
Hawaii
:usa:
The only thing it does not have is a VEC II or an AEM. If you have your own fuel management you are good to go with bolting it on. In your case with a 00 I wouldn't go higher than 6psi. $5,000 is my asking price. I believe these injectors are bigger than what initially comes in a ROE kit.
The car ran a sub 10 on the 10psi pulley and cracked a 9.90 with a little N20.
Gus//
Steve 00RT/10
Michigan
so what does that mean?
is it a bad thing?
I believe the rear intake area was redone a few times over the years to help correct the 9/10 plug fouling issues by modifying the air flow. I have one of each. The older ones are pretty much a square or rectangular intake set up. My newer one (production run #6) is more of a tapered design. Those improvements, along with the VEC II gaining the individual cylinder trim parameters pretty much eliminated the plug fouling issues.
Gus//
My January/2006 kit came with 50 pound injectors. I belive 29 pounders are OEM for a 2000 car. Certainly a good buy, but unless you are having it installed by someone familiar with the procedure and/or are a pretty good wrench turner, I would let Sean refurbish it and send it back to you. I don't think he charges that much to do this. That way it's all packed up the way the instructions direct you. You most definitely have to have A VEC II or III or some other sort of fuel management system.
5 pounds is the safe limit w/o water ****. Then 6.5 is it for cast piston cars.
Even a mere 5 pounder will produce large smiles :headbang:
Steve
1TONY1
Dalton Ga. (Chatt. Tn.)
Are you talking the piece on the rear of the blower ? I can't tell from the pictures but I like the oldest style better.....looks like it would flow better....and we already know that style is the fastest and quickest :D
That piece shouldn't have anything to do with the plugs.
Ross L
