Sensor circuit high voltage
OVERBOOST
Panama City, FL
Check engine light
Codes
0138---sensor circuit high voltage (bank 1 sensor 2)
0158---sensor circuit high voltage (bank 2 sensor 2)
So I change both 02 sensors and reset the PCM. After 4 min
check engine light and same codes :confused: . What do I need to do???
Its a 97'GTS with a paxton.
Jack B
NE Ohio
1. Bad sensor.
2. Car is actually running rich.
3. A short from another 5 volt source.
Use a scan tool and look at the actual waveform and voltage, that will answer the question.
