Shifter loose!!!!
scottgf
Southern California. USA
<FONT COLOR="Red">Text</FONT c>
I think my snake has a problem.
When I pull up on the shifter of my 94 RT/10 it becomes disconnected from the trans. Is this normal?
I looked at my Service Manual but it didnt have a good picture of the shifter. Does it have a threaded shaft, or is there some sort of clip that holds it in place?
I tried to take a look at the shifter myself, but it looks like a real pain to remove the plate that attaches the lower boot to the floor.
HELP!!
Thanks in advance.
Scott
Tom Sessions
Hampstead,NC.
Scott,There is a isolator in the base of the shifter to absorb vibrations from the trans and it sounds like it has broken loose.Two shafts mounted in a hard rubber.The replacement part is quite expensive so your best bet is to go with a short throw shifter or find someone that has put one in and has the stock shifter parts left over.You may be able to go to a machine shop and have a new rod made also that goes between the shift knob and the shifter base.
scottgf
Tom,
Being a Viper Tech. and all, do you think this is something that a "Added Care Plus" extended warranty would cover?
Thanks,
Scott
Quantico, VA
Make you own bolt. The shift knob is 1/2-20 and the shifter is 12mm-1.75. Cut to the size you want. I dropped mine about 1". My shifter did the same thing yours did while I was on the drag strip. On thing you could try is to glue the shift isolator back together.
ACR Joe
Newtown, PA
Should you need to replace the shifter, following is my previous post detailing shifter R&R:
